[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.frame/select.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:16 EST 2007
Hello glynn,
ANALYSIS
display/d.frame/select.c functions
main (Begins at: 16 Ends at: 67)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
