[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/raster_rgb.c |3 clones ( curses.c graphics.c mouse.c signature.c plot.c main.c main.c main.c main.c main.c main.c graphics.c graphics.c graphics.c graphics.c graphics.c c_update.c d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c raster_rgb.c )| 3 monsters | 4 warnings
Thu Mar 1 19:38:23 EST 2007
Hello glynn,
ANALYSIS
lib/display/raster_rgb.c functions
D_draw_raster_RGB (Begins at: 48 Ends at: 58)
Complexity:   |       1 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
1 metric are OUT OF RANGE!
D_draw_d_raster_RGB (Begins at: 60 Ends at: 69)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      10 |       |      OK |
at least 1 values are close to an outlier please consider revising code
D_draw_f_raster_RGB (Begins at: 71 Ends at: 80)
LOC:          |      10 |       |      OK |
D_draw_c_raster_RGB (Begins at: 82 Ends at: 91)
LOC:          |      10 |       |      OK |
D_draw_cell_RGB (Begins at: 93 Ends at: 102)
LOC:          |      10 |       |      OK |
draw_cell_RGB (Begins at: 104 Ends at: 191)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      88 |       |      OK |
D_cell_draw_setup_RGB (Begins at: 193 Ends at: 236)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
D_raster_of_type_RGB (Begins at: 238 Ends at: 284)
Complexity:   |       2 |       |      OK |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |      17 |       |      OK |
LOC:          |      47 |       |      OK |
D_set_colors_RGB (Begins at: 286 Ends at: 295)
ParamNBR:     |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
  D_draw_c_raster_RGB  D_draw_f_raster_RGB  D_draw_d_raster_RGB
In lib/display/raster_rgb.c clones of  D_draw_d_raster_RGB are:
	lib/display/raster_rgb.c  D_draw_c_raster_RGB
	lib/display/raster_rgb.c  D_draw_f_raster_RGB
In lib/display/raster_rgb.c clones of  D_draw_f_raster_RGB are:
	lib/display/raster_rgb.c  D_draw_d_raster_RGB
In lib/display/raster_rgb.c clones of  D_draw_c_raster_RGB are:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
