[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/headerinfo.c |no clones | 0 monsters | 2 warnings
Thu Mar 1 19:38:40 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/headerinfo.c functions
G3d_getCoordsMap (Begins at: 20 Ends at: 26)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
G3d_getCoordsMapWindow (Begins at: 31 Ends at: 53)
LOC:          |      23 |       |      OK |
metrics are OK
G3d_getNofTilesMap (Begins at: 56 Ends at: 80)
LOC:          |      25 |       |      OK |
metrics are OK
G3d_getRegionMap (Begins at: 83 Ends at: 92)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      10 |       |      OK |
at least 1 values are close to an outlier please consider revising code
G3d_getWindowMap (Begins at: 97 Ends at: 119)
LOC:          |      23 |       |      OK |
G3d_getRegionStructMap (Begins at: 122 Ends at: 126)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
G3d_getWindowStructMap (Begins at: 131 Ends at: 150)
LOC:          |      20 |       |      OK |
metrics are OK
G3d_getTileDimensionsMap (Begins at: 153 Ends at: 171)
LOC:          |      19 |       |      OK |
metrics are OK
G3d_tileTypeMap (Begins at: 174 Ends at: 190)
ParamNBR:     |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G3d_fileTypeMap (Begins at: 193 Ends at: 209)
LOC:          |      17 |       |      OK |
metrics are OK
G3d_tilePrecisionMap (Begins at: 212 Ends at: 228)
LOC:          |      17 |       |      OK |
metrics are OK
G3d_tileUseCacheMap (Begins at: 231 Ends at: 246)
LOC:          |      16 |       |      OK |
metrics are OK
G3d_printHeader (Begins at: 249 Ends at: 298)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
