[GRASS-QA] GRASS QA: soeren | ./grass6/lib/g3d/filecompare.c |2 clones ( curses.c graphics.c mouse.c signature.c plot.c main.c main.c main.c main.c main.c main.c graphics.c graphics.c graphics.c graphics.c graphics.c c_update.c d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c raster_rgb.c raster_rgb.c Get_location.c com_proto.c com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c i_face.c main.c main.c level_two.c main.c build.c line.c read_nat.c areas.c filecompare.c )| 0 monsters | 0 warnings
Thu Mar 1 19:38:39 EST 2007
Hello soeren,
ANALYSIS
lib/g3d/filecompare.c functions
G3d_float2xdrFloat (Begins at: 17 Ends at: 31)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G3d_double2xdrDouble (Begins at: 36 Ends at: 50)
LOC:          |      15 |       |      OK |
metrics are OK
G3d_truncFloat (Begins at: 55 Ends at: 82)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
G3d_truncDouble (Begins at: 87 Ends at: 156)
Complexity:   |       8 |       |      OK |
LOC:          |      70 |       |      OK |
metrics are OK
G3d_float2Double (Begins at: 161 Ends at: 197)
Complexity:   |       2 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
G3d_compareFloats (Begins at: 202 Ends at: 228)
ParamNBR:     |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
G3d_compareDoubles (Begins at: 234 Ends at: 262)
LOC:          |      29 |       |      OK |
metrics are OK
G3d_compareFloatDouble (Begins at: 268 Ends at: 308)
CalledNBR:    |       7 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
compareFilesNocache (Begins at: 313 Ends at: 395)
CalledNBR:    |      17 |       |      OK |
LOC:          |      83 |       |      OK |
metrics are OK
G3d_compareFiles (Begins at: 398 Ends at: 511)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      44 |     * |         |
LOC:          |     114 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  G3d_double2xdrDouble  G3d_float2xdrFloat
In lib/g3d/filecompare.c clones of  G3d_float2xdrFloat are:
	lib/g3d/filecompare.c  G3d_double2xdrDouble
In lib/g3d/filecompare.c clones of  G3d_double2xdrDouble are:
	lib/g3d/filecompare.c  G3d_float2xdrFloat
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
