[GRASS-QA] GRASS QA: glynn | ./grass6/db/base/describe.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:15 EST 2007
Hello glynn,
ANALYSIS
db/base/describe.c functions
main (Begins at: 22 Ends at: 68)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
parse_command_line (Begins at: 71 Ends at: 121)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
