[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.digit/symb.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:29 EST 2007
Hello glynn,
ANALYSIS
vector/v.digit/symb.c functions
get_symb_code (Begins at: 51 Ends at: 66)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
get_symb_name (Begins at: 70 Ends at: 77)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
symb_init (Begins at: 81 Ends at: 92)
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
symb_init_gui (Begins at: 96 Ends at: 105)
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
symb_set_driver_color (Begins at: 109 Ends at: 115)
LOC:          |       7 |       |      OK |
metrics are OK
symb_line_from_map (Begins at: 121 Ends at: 154)
Complexity:   |      12 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
symb_lines_init (Begins at: 158 Ends at: 168)
CalledNBR:    |       5 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
symb_line_set_from_map (Begins at: 172 Ends at: 181)
LOC:          |      10 |       |      OK |
metrics are OK
symb_updated_lines_set_from_map (Begins at: 185 Ends at: 196)
LOC:          |      12 |       |      OK |
metrics are OK
symb_node_from_map (Begins at: 201 Ends at: 221)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
symb_node_set_from_map (Begins at: 225 Ends at: 234)
LOC:          |      10 |       |      OK |
metrics are OK
symb_nodes_init (Begins at: 238 Ends at: 248)
LOC:          |      11 |       |      OK |
metrics are OK
symb_updated_nodes_set_from_map (Begins at: 252 Ends at: 262)
LOC:          |      11 |       |      OK |
metrics are OK
updated_lines_and_nodes_erase_refresh_display (Begins at: 265 Ends at: 275)
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
