[GRASS-QA] GRASS QA: glynn | ./grass6/lib/db/dbmi_driver/d_drop_index.c |1 clones ( curses.c graphics.c mouse.c signature.c plot.c main.c main.c main.c main.c main.c main.c graphics.c graphics.c graphics.c graphics.c graphics.c c_update.c d_drop_index.c )| 0 monsters | 0 warnings
Thu Mar 1 19:38:22 EST 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_driver/d_drop_index.c functions
db_d_drop_index (Begins at: 12 Ends at: 37)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  db_d_drop_index
In lib/db/dbmi_driver/d_drop_index.c clones of  db_d_drop_index are:
	lib/db/dbmi_driver/d_drop_tab.c  db_d_drop_table
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
