[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.class/set_signals.c |no clones | 0 monsters | 0 warnings
Thu Mar 1 19:38:15 EST 2007
Hello brad,
ANALYSIS
imagery/i.class/set_signals.c functions
set_signals (Begins at: 7 Ends at: 21)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
