[GRASS-QA] GRASS QA: markus | ./grass6/general/g.region/cmd/printwindow.c |no clones | 3 monsters | 0 warnings
Thu Mar 1 19:38:31 EST 2007
Hello markus,
ANALYSIS
general/g.region/cmd/printwindow.c functions
print_window (Begins at: 9 Ends at: 470)
Complexity:   |      56 |   *** | MONSTER |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |     188 |   *** | MONSTER |
LOC:          |     462 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
