[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/build.c |2 clones ( curses.c graphics.c mouse.c signature.c plot.c main.c main.c main.c main.c main.c main.c graphics.c graphics.c graphics.c graphics.c graphics.c c_update.c d_drop_index.c d_drop_tab.c list.c raster_rgb.c raster_rgb.c raster_rgb.c raster_rgb.c Get_location.c com_proto.c com_proto.c com_proto.c loc_proto.c loc_proto.c loc_proto.c i_face.c main.c main.c level_two.c main.c build.c )| 0 monsters | 0 warnings
Thu Mar 1 19:38:34 EST 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/build.c functions
prnmsg (Begins at: 43 Ends at: 56)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Vect_build (Begins at: 65 Ends at: 75)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Vect_get_built (Begins at: 78 Ends at: 115)
CalledNBR:    |       0 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Vect_build_partial (Begins at: 118 Ends at: 225)
Complexity:   |      18 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      46 |     * |         |
LOC:          |     108 |       |      OK |
metrics are OK
Vect_save_topo (Begins at: 234 Ends at: 266)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Vect_topo_dump (Begins at: 275 Ends at: 364)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
Vect_save_spatial_index (Begins at: 373 Ends at: 405)
LOC:          |      33 |       |      OK |
metrics are OK
Vect_spatial_index_dump (Begins at: 414 Ends at: 425)
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  Vect_save_spatial_index  Vect_save_topo
In lib/vector/Vlib/build.c clones of  Vect_save_topo are:
	lib/vector/Vlib/build.c  Vect_save_spatial_index
In lib/vector/Vlib/build.c clones of  Vect_save_spatial_index are:
	lib/vector/Vlib/build.c  Vect_save_topo
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
