[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.rgb.his/openfiles.c |1 clones ( closefiles.c openfiles.c )| 0 monsters | 0 warnings
Thu Mar 1 23:29:16 EST 2007
Hello brad,
ANALYSIS
imagery/i.rgb.his/openfiles.c functions
openfiles (Begins at: 6 Ends at: 35)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  openfiles
In imagery/i.rgb.his/openfiles.c clones of  openfiles are:
	imagery/i.his.rgb/openfiles.c  openfiles
Threshold GRASS6 key metrics values at 2007-03-01 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
