[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/scale.c |no clones | 0 monsters | 0 warnings
Mon Mar 5 23:55:00 EST 2007
Hello glynn,
ANALYSIS
lib/driver/scale.c functions
scale (Begins at: 14 Ends at: 17)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
scale_fwd_y (Begins at: 19 Ends at: 22)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
scale_rev_x (Begins at: 24 Ends at: 27)
LOC:          |       4 |       |      OK |
metrics are OK
next_row (Begins at: 29 Ends at: 40)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
alloc_buffers (Begins at: 42 Ends at: 53)
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
LIB_begin_scaled_raster (Begins at: 55 Ends at: 68)
CalledNBR:    |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
LIB_scaled_raster (Begins at: 70 Ends at: 98)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       6 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-05 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
