[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.path/select.c |no clones | 0 monsters | 1 warnings
Tue Mar 20 06:13:07 EDT 2007
Hello hamish,
ANALYSIS
display/d.path/select.c functions
path (Begins at: 18 Ends at: 156)
Complexity:   |      19 |     * |         |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      54 |     * |         |
LOC:          |     139 |     * |         |
metrics are OK
display (Begins at: 159 Ends at: 177)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
coor_path (Begins at: 183 Ends at: 266)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      26 |       |      OK |
LOC:          |      84 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
