[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.lrs/v.lrs.create/main.c |1 clones ( main.c )| 3 monsters | 0 warnings
Tue May 1 15:17:03 EDT 2007
Hello markus,
ANALYSIS
vector/v.lrs/v.lrs.create/main.c functions
main (Begins at: 80 Ends at: 793)
Complexity:   |      61 |   *** | MONSTER |
CalledNBR:    |     256 |   *** | MONSTER |
LOC:          |     714 |   *** | MONSTER |
3 metric are OUT OF RANGE!
cmp_along (Begins at: 795 Ends at: 807)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  cmp_along
In vector/v.lrs/v.lrs.create/main.c clones of  cmp_along are:
	imagery/i.class/edge_order.c  edge_order
Threshold GRASS6 key metrics values at 2007-05-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
