[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/rotate.c |no clones | 0 monsters | 0 warnings
Wed May 2 03:16:53 EDT 2007
Hello hamish,
ANALYSIS
lib/gis/rotate.c functions
G_rotate_around_point (Begins at: 32 Ends at: 59)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
G_rotate_around_point_int (Begins at: 61 Ends at: 72)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
