[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.edit/snap.c |no clones | 0 monsters | 0 warnings
Wed May 2 14:31:29 EDT 2007
Hello markus,
ANALYSIS
vector/v.edit/snap.c functions
do_snap (Begins at: 30 Ends at: 94)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
