[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.setup/ask_group.c |no clones | 0 monsters | 0 warnings
Sun May 6 21:20:50 EDT 2007
Hello hamish,
ANALYSIS
raster/r.le/r.le.setup/ask_group.c functions
ask_group (Begins at: 40 Ends at: 79)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
get_group_drv (Begins at: 85 Ends at: 134)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
ask_limits (Begins at: 141 Ends at: 154)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
get_index (Begins at: 160 Ends at: 183)
Complexity:   |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
ask_reclass (Begins at: 189 Ends at: 232)
CalledNBR:    |      17 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
get_1recl (Begins at: 239 Ends at: 298)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
ask_fromto (Begins at: 306 Ends at: 329)
CalledNBR:    |      11 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
fopen0 (Begins at: 335 Ends at: 346)
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-06 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
