[GRASS-QA] GRASS QA: paul | ./grass6/lib/gis/paths.c |no clones | 0 monsters | 0 warnings
Mon May 7 19:50:59 EDT 2007
Hello paul,
ANALYSIS
lib/gis/paths.c functions
G_mkdir (Begins at: 17 Ends at: 33)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_is_dirsep (Begins at: 35 Ends at: 50)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_is_absolute_path (Begins at: 52 Ends at: 71)
LOC:          |      20 |       |      OK |
metrics are OK
G_convert_dirseps_to_host (Begins at: 73 Ends at: 93)
LOC:          |      21 |       |      OK |
metrics are OK
G_convert_dirseps_from_host (Begins at: 95 Ends at: 116)
LOC:          |      22 |       |      OK |
metrics are OK
G_stat (Begins at: 118 Ends at: 133)
LOC:          |      16 |       |      OK |
metrics are OK
G_lstat (Begins at: 135 Ends at: 142)
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-07 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
