[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/XDRIVER/Polygon.c |no clones | 0 monsters | 0 warnings
Wed May 9 17:12:11 EDT 2007
Hello glynn,
ANALYSIS
display/drivers/XDRIVER/Polygon.c functions
XD_Polygon_abs (Begins at: 9 Ends at: 25)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
XD_Polygon_rel (Begins at: 27 Ends at: 46)
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-09 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
