[GRASS-QA] GRASS QA: moritz | ./grass6/vector/v.net.path/path.c |no clones | 1 monsters | 0 warnings
Sun May 13 09:44:45 EDT 2007
Hello moritz,
ANALYSIS
vector/v.net.path/path.c functions
path (Begins at: 25 Ends at: 281)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |     106 |   *** | MONSTER |
LOC:          |     257 |    ** | Warning |
1 metric are OUT OF RANGE!
cmp (Begins at: 283 Ends at: 291)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
