[GRASS-QA] GRASS QA: scott | ./grass6/lib/edit/edit_cats.c |no clones | 0 monsters | 0 warnings
Mon May 14 15:46:49 EDT 2007
Hello scott,
ANALYSIS
lib/edit/edit_cats.c functions
E_edit_cats (Begins at: 58 Ends at: 232)
Complexity:   |      21 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      43 |     * |         |
LOC:          |     175 |     * |         |
metrics are OK
E_edit_fp_cats (Begins at: 234 Ends at: 384)
Complexity:   |      17 |     * |         |
CalledNBR:    |      48 |     * |         |
LOC:          |     151 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-14 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
