[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.class/signature.c |1 clones ( curses.c signature.c )| 0 monsters | 0 warnings
Wed May 16 17:04:21 EDT 2007
Hello markus,
ANALYSIS
imagery/i.class/signature.c functions
init_sig_routines (Begins at: 38 Ends at: 57)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
prepare_signature (Begins at: 64 Ends at: 156)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
show_signature (Begins at: 172 Ends at: 244)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      73 |       |      OK |
metrics are OK
done (Begins at: 246 Ends at: 249)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
display_signature (Begins at: 254 Ends at: 314)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
have_signature (Begins at: 322 Ends at: 325)
LOC:          |       4 |       |      OK |
metrics are OK
save_signature (Begins at: 333 Ends at: 347)
CalledNBR:    |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
yes_save (Begins at: 349 Ends at: 376)
CalledNBR:    |       6 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
dont_save (Begins at: 379 Ends at: 382)
LOC:          |       4 |       |      OK |
metrics are OK
write_signatures (Begins at: 389 Ends at: 398)
CalledNBR:    |       5 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  write_signatures
In imagery/i.class/signature.c clones of  write_signatures are:
	display/d.rast.edit/edit.c  use_mouse
Threshold GRASS6 key metrics values at 2007-05-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
