[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/sleep.c |no clones | 0 monsters | 0 warnings
Fri May 18 10:45:58 EDT 2007
Hello markus,
ANALYSIS
lib/gis/sleep.c functions
G_sleep (Begins at: 11 Ends at: 20)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-18 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
