[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.info/main.c |no clones | 2 monsters | 0 warnings
Mon May 21 03:12:27 EDT 2007
Hello hamish,
ANALYSIS
raster/r.info/main.c functions
main (Begins at: 36 Ends at: 362)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |     135 |   *** | MONSTER |
LOC:          |     327 |   *** | MONSTER |
2 metric are OUT OF RANGE!
format_double (Begins at: 366 Ends at: 370)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
compose_line (Begins at: 373 Ends at: 388)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
