[GRASS-QA] GRASS QA: moritz | ./grass6/general/g.mapset/main.c |no clones | 0 monsters | 1 warnings
Thu May 24 07:38:27 EDT 2007
Hello moritz,
ANALYSIS
general/g.mapset/main.c functions
main (Begins at: 30 Ends at: 194)
Complexity:   |      18 |     * |         |
CalledNBR:    |      76 |    ** | Warning |
LOC:          |     165 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
