[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/ls.c |no clones | 0 monsters | 0 warnings
Fri May 25 06:10:58 EDT 2007
Hello martinl,
ANALYSIS
lib/gis/ls.c functions
cmp_names (Begins at: 30 Ends at: 52)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
G__ls (Begins at: 54 Ends at: 92)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
G_ls (Begins at: 94 Ends at: 124)
CalledNBR:    |       4 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
G_ls_format (Begins at: 126 Ends at: 182)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-05-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
