[GRASS-QA] GRASS QA: moritz | ./grass6/lib/vask/V_call.c |no clones | 2 monsters | 0 warnings
Thu Nov 1 10:28:19 EDT 2007
Hello moritz,
ANALYSIS
lib/vask/V_call.c functions
V_call (Begins at: 147 Ends at: 457)
Complexity:   |      64 |   *** | MONSTER |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      87 |   *** | MONSTER |
LOC:          |     311 |   *** | MONSTER |
2 metric are OUT OF RANGE!
V_intrpt_ok (Begins at: 459 Ends at: 477)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
V_intrpt_msg (Begins at: 479 Ends at: 482)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
fmt (Begins at: 485 Ends at: 500)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
centered (Begins at: 503 Ends at: 513)
Complexity:   |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
