[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.vol.rst/main.c |no clones | 3 monsters | 0 warnings
Mon Nov 5 09:22:07 EST 2007
Hello markus,
ANALYSIS
vector/v.vol.rst/main.c functions
main (Begins at: 158 Ends at: 813)
Complexity:   |      86 |   *** | MONSTER |
CalledNBR:    |     275 |   *** | MONSTER |
LOC:          |     656 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-05 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
