[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/error.c |no clones | 0 monsters | 0 warnings
Sun Nov 11 22:02:20 EST 2007
Hello glynn,
ANALYSIS
lib/gis/error.c functions
G_message (Begins at: 107 Ends at: 130)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_verbose_message (Begins at: 132 Ends at: 158)
LOC:          |      27 |       |      OK |
metrics are OK
G_important_message (Begins at: 160 Ends at: 194)
LOC:          |      35 |       |      OK |
metrics are OK
G_fatal_error (Begins at: 196 Ends at: 221)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
G_warning (Begins at: 223 Ends at: 244)
CalledNBR:    |       4 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_suppress_warnings (Begins at: 246 Ends at: 263)
CalledNBR:    |       0 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
G_sleep_on_error (Begins at: 265 Ends at: 283)
LOC:          |      19 |       |      OK |
metrics are OK
G_set_error_routine (Begins at: 285 Ends at: 299)
ParamNBR:     |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_unset_error_routine (Begins at: 301 Ends at: 306)
LOC:          |       6 |       |      OK |
metrics are OK
print_error (Begins at: 309 Ends at: 360)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
log_error (Begins at: 362 Ends at: 397)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
write_error (Begins at: 400 Ends at: 432)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
mail_msg (Begins at: 435 Ends at: 453)
Complexity:   |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
print_word (Begins at: 456 Ends at: 507)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
print_sentence (Begins at: 510 Ends at: 559)
CalledNBR:    |      12 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
G_info_format (Begins at: 561 Ends at: 578)
CalledNBR:    |       3 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-11 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
