[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/ls.c |no clones | 0 monsters | 0 warnings
Sun Nov 11 22:02:23 EST 2007
Hello glynn,
ANALYSIS
lib/gis/ls.c functions
cmp_names (Begins at: 31 Ends at: 53)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
G__ls (Begins at: 55 Ends at: 93)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
G_ls (Begins at: 95 Ends at: 123)
CalledNBR:    |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
G_ls_format (Begins at: 125 Ends at: 181)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-11 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
