[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/gets.c |no clones | 0 monsters | 0 warnings
Mon Nov 12 06:41:23 EST 2007
Hello glynn,
ANALYSIS
lib/gis/gets.c functions
G_gets (Begins at: 38 Ends at: 73)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
catch_ctrlz (Begins at: 75 Ends at: 93)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
catch_int (Begins at: 95 Ends at: 97)
CalledNBR:    |       0 |       |      OK |
LOC:          |       3 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
