[GRASS-QA] GRASS QA: hamish | ./grass6/lib/vector/Vlib/array.c |no clones | 0 monsters | 0 warnings
Tue Nov 13 07:07:35 EST 2007
Hello hamish,
ANALYSIS
lib/vector/Vlib/array.c functions
Vect_new_varray (Begins at: 37 Ends at: 67)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Vect_set_varray_from_cat_string (Begins at: 70 Ends at: 104)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       7 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
Vect_set_varray_from_cat_list (Begins at: 107 Ends at: 171)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
cmp (Begins at: 174 Ends at: 182)
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
in_array (Begins at: 185 Ends at: 207)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Vect_set_varray_from_db (Begins at: 210 Ends at: 316)
CalledNBR:    |      20 |       |      OK |
LOC:          |     107 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
