[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.report/prt_report.c |no clones | 0 monsters | 2 warnings
Fri Nov 16 06:29:49 EST 2007
Hello hamish,
ANALYSIS
raster/r.report/prt_report.c functions
print_report (Begins at: 5 Ends at: 274)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      37 |     * |         |
LOC:          |     270 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
construct_val_str (Begins at: 276 Ends at: 308)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
construct_cat_label (Begins at: 310 Ends at: 338)
CalledNBR:    |       7 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
