[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.los/pts_elim.c |no clones | 1 monsters | 0 warnings
Sun Nov 18 06:03:49 EST 2007
Hello markus,
ANALYSIS
raster/r.los/pts_elim.c functions
hidden_point_elimination (Begins at: 41 Ends at: 233)
Complexity:   |      14 |       |      OK |
ParamNBR:     |      11 |   *** | MONSTER |
CalledNBR:    |      13 |       |      OK |
LOC:          |     193 |     * |         |
1 metric are OUT OF RANGE!
find_orientation (Begins at: 236 Ends at: 278)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
find_inclination (Begins at: 281 Ends at: 297)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       5 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-18 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
