[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/key_value2.c |no clones | 0 monsters | 0 warnings
Thu Nov 22 07:08:20 EST 2007
Hello hamish,
ANALYSIS
lib/gis/key_value2.c functions
G_fwrite_key_value (Begins at: 7 Ends at: 22)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_fread_key_value (Begins at: 25 Ends at: 52)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
