[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/getl.c |no clones | 0 monsters | 0 warnings
Thu Nov 22 16:50:18 EST 2007
Hello glynn,
ANALYSIS
lib/gis/getl.c functions
G_getl (Begins at: 17 Ends at: 50)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
G_getl2 (Begins at: 52 Ends at: 86)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
