[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/postgres/execute.c |2 clones ( execute.c )| 0 monsters | 0 warnings
Sat Nov 24 08:23:04 EST 2007
Hello markus,
ANALYSIS
db/drivers/postgres/execute.c functions
db__driver_execute_immediate (Begins at: 20 Ends at: 57)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
db__driver_begin_transaction (Begins at: 59 Ends at: 78)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
db__driver_commit_transaction (Begins at: 80 Ends at: 99)
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  db__driver_commit_transaction  db__driver_begin_transaction
In db/drivers/postgres/execute.c clones of  db__driver_begin_transaction are:
	db/drivers/postgres/execute.c  db__driver_commit_transaction
In db/drivers/postgres/execute.c clones of  db__driver_commit_transaction are:
	db/drivers/postgres/execute.c  db__driver_begin_transaction
Threshold GRASS6 key metrics values at 2007-11-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
