[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.in.ascii/points.c |no clones | 2 monsters | 0 warnings
Sun Nov 25 06:16:06 EST 2007
Hello martinl,
ANALYSIS
vector/v.in.ascii/points.c functions
is_int (Begins at: 14 Ends at: 27)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
is_double (Begins at: 32 Ends at: 63)
Complexity:   |       6 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
points_analyse (Begins at: 65 Ends at: 270)
Complexity:   |      32 |    ** | Warning |
ParamNBR:     |      12 |   *** | MONSTER |
CalledNBR:    |      51 |     * |         |
LOC:          |     206 |    ** | Warning |
1 metric are OUT OF RANGE!
points_to_bin (Begins at: 272 Ends at: 405)
Complexity:   |      16 |     * |         |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      57 |     * |         |
LOC:          |     134 |     * |         |
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
