[GRASS-QA] GRASS QA: carlos | ./grass6/imagery/i.smap/shapiro/closefiles.c |no clones | 0 monsters | 0 warnings
Tue Nov 27 13:41:11 EST 2007
Hello carlos,
ANALYSIS
imagery/i.smap/shapiro/closefiles.c functions
closefiles (Begins at: 9 Ends at: 25)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-27 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
