[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.cross/main.c |no clones | 0 monsters | 1 warnings
Tue Nov 27 13:41:12 EST 2007
Hello carlos,
ANALYSIS
raster/r.cross/main.c functions
main (Begins at: 30 Ends at: 201)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      73 |    ** | Warning |
LOC:          |     172 |     * |         |
at least 1 values are close to an outlier please consider revising code
cmp (Begins at: 203 Ends at: 214)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-27 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
