[GRASS-QA] GRASS QA: carlos | ./grass6/ps/ps.map/ps_fclrtbl.c |no clones | 0 monsters | 1 warnings
Wed Nov 28 13:37:02 EST 2007
Hello carlos,
ANALYSIS
ps/ps.map/ps_fclrtbl.c functions
PS_fcolortable (Begins at: 17 Ends at: 227)
Complexity:   |      23 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      50 |     * |         |
LOC:          |     211 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-28 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
