[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/dbf/table.c |no clones | 0 monsters | 0 warnings
Thu Nov 29 08:38:00 EST 2007
Hello markus,
ANALYSIS
db/drivers/dbf/table.c functions
add_table (Begins at: 40 Ends at: 68)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
find_table (Begins at: 72 Ends at: 85)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
load_table_head (Begins at: 88 Ends at: 150)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
load_table (Begins at: 153 Ends at: 217)
Complexity:   |       8 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
save_table (Begins at: 220 Ends at: 318)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
free_table (Begins at: 320 Ends at: 339)
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-29 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
