[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/a2b.c |1 clones ( a2b.c )| 0 monsters | 1 warnings
Mon Oct 8 05:34:32 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/a2b.c functions
asc_to_bin (Begins at: 16 Ends at: 187)
Complexity:   |      31 |    ** | Warning |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      44 |     * |         |
LOC:          |     172 |     * |         |
at least 1 values are close to an outlier please consider revising code
read_head (Begins at: 190 Ends at: 239)
Complexity:   |      18 |     * |         |
CalledNBR:    |      33 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
do_close (Begins at: 247 Ends at: 302)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
do_snapping (Begins at: 309 Ends at: 365)
ParamNBR:     |       5 |     * |         |
LOC:          |      57 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  read_head
In vector/v.edit/a2b.c clones of  read_head are:
	vector/v.in.ascii/head.c  read_head
Threshold GRASS6 key metrics values at 2007-10-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
