[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/vertex.c |no clones | 0 monsters | 1 warnings
Mon Oct 8 05:34:34 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/vertex.c functions
do_move_vertex (Begins at: 29 Ends at: 127)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      21 |       |      OK |
LOC:          |      99 |       |      OK |
at least 1 values are close to an outlier please consider revising code
do_add_vertex (Begins at: 129 Ends at: 210)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      23 |       |      OK |
LOC:          |      82 |       |      OK |
metrics are OK
do_remove_vertex (Begins at: 218 Ends at: 295)
CalledNBR:    |      20 |       |      OK |
LOC:          |      78 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
