[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/max_distance.c |no clones | 0 monsters | 0 warnings
Mon Oct 8 05:34:33 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/max_distance.c functions
max_distance (Begins at: 27 Ends at: 77)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
min_distance_line (Begins at: 79 Ends at: 113)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
coord2bbox (Begins at: 118 Ends at: 131)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
