[GRASS-QA] GRASS QA: brad | ./grass6/db/base/describe.c |no clones | 0 monsters | 0 warnings
Mon Oct 8 23:32:06 EDT 2007
Hello brad,
ANALYSIS
db/base/describe.c functions
main (Begins at: 31 Ends at: 85)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
parse_command_line (Begins at: 88 Ends at: 131)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
