[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/select.c |no clones | 0 monsters | 0 warnings
Tue Oct 9 13:24:05 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/select.c functions
select_lines (Begins at: 26 Ends at: 89)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      64 |       |      OK |
metrics are OK
do_print_selected (Begins at: 97 Ends at: 109)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
sel_by_cat (Begins at: 116 Ends at: 162)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      10 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
sel_by_coordinates (Begins at: 169 Ends at: 216)
CalledNBR:    |      14 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
sel_by_bbox (Begins at: 223 Ends at: 263)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
sel_by_polygon (Begins at: 270 Ends at: 316)
LOC:          |      47 |       |      OK |
metrics are OK
sel_by_id (Begins at: 323 Ends at: 366)
LOC:          |      44 |       |      OK |
metrics are OK
sel_by_where (Begins at: 373 Ends at: 446)
CalledNBR:    |      25 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
merge_lists (Begins at: 449 Ends at: 467)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
reverse_selection (Begins at: 470 Ends at: 488)
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-09 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
