[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/find.c |no clones | 0 monsters | 1 warnings
Wed Oct 10 12:19:52 EDT 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/find.c functions
Vect_find_node (Begins at: 59 Ends at: 126)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
Vect_find_line (Begins at: 129 Ends at: 215)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      10 |       |      OK |
LOC:          |      87 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Vect_find_area (Begins at: 218 Ends at: 260)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
Vect_find_island (Begins at: 263 Ends at: 312)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
