[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/raster.c |4 clones ( raster.c )| 0 monsters | 0 warnings
Thu Oct 11 03:02:39 EDT 2007
Hello brad,
ANALYSIS
lib/gis/raster.c functions
G_incr_void_ptr (Begins at: 32 Ends at: 54)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
G_raster_cmp (Begins at: 56 Ends at: 100)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
G_raster_cpy (Begins at: 102 Ends at: 123)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_set_raster_value_c (Begins at: 125 Ends at: 159)
Complexity:   |       6 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_set_raster_value_f (Begins at: 161 Ends at: 195)
LOC:          |      35 |       |      OK |
metrics are OK
G_set_raster_value_d (Begins at: 197 Ends at: 235)
LOC:          |      39 |       |      OK |
metrics are OK
G_get_raster_value_c (Begins at: 237 Ends at: 270)
LOC:          |      34 |       |      OK |
metrics are OK
G_get_raster_value_f (Begins at: 272 Ends at: 305)
LOC:          |      34 |       |      OK |
metrics are OK
G_get_raster_value_d (Begins at: 307 Ends at: 325)
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  G_set_raster_value_f  G_set_raster_value_c  G_get_raster_value_f  G_get_raster_value_c
In lib/gis/raster.c clones of  G_get_raster_value_c are:
	lib/gis/raster.c  G_get_raster_value_f
In lib/gis/raster.c clones of  G_set_raster_value_f are:
	lib/gis/raster.c  G_set_raster_value_c
In lib/gis/raster.c clones of  G_set_raster_value_c are:
	lib/gis/raster.c  G_set_raster_value_f
In lib/gis/raster.c clones of  G_get_raster_value_f are:
	lib/gis/raster.c  G_get_raster_value_c
Threshold GRASS6 key metrics values at 2007-10-11 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
