[GRASS-QA] GRASS QA: glynn | ./grass6/lib/db/dbmi_base/xdrint.c |2 clones ( xdrchar.c xdrdouble.c xdrfloat.c xdrint.c )| 0 monsters | 0 warnings
Mon Oct 15 03:00:44 EDT 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_base/xdrint.c functions
db__send_int (Begins at: 6 Ends at: 21)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
db__recv_int (Begins at: 24 Ends at: 40)
LOC:          |      17 |       |      OK |
metrics are OK
db__send_int_array (Begins at: 43 Ends at: 66)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
db__recv_int_array (Begins at: 71 Ends at: 120)
Complexity:   |      10 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  db__send_int  db__recv_int_array
In lib/db/dbmi_base/xdrint.c clones of  db__send_int are:
	lib/db/dbmi_base/xdrfloat.c  db__send_float
	lib/db/dbmi_base/xdrdouble.c  db__recv_double
	lib/db/dbmi_base/xdrchar.c  db__recv_char
In lib/db/dbmi_base/xdrint.c clones of  db__recv_int_array are:
	lib/db/dbmi_base/xdrshort.c  db__recv_short_array
Threshold GRASS6 key metrics values at 2007-10-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
